Sportsman 800 top speed?
Old 11-02-2009, 09:04 PM
bitterfitter's Avatar
Speedo's are generally inaccurate on quads. Or maybe inconsistent is better. Tire pressure, belt slippage, bigger or smaller tires are all variables. But there are also differences in performance on quads of the same model year to year, and even quad to quad. I have the slower of the two 850XP's purchased together, even of the difference is minimal, it's enough to be noticable, and enough for me to be thinking aftermarket exhaust.
Old 11-02-2009, 10:15 PM
popoman's Avatar
yep while top speed isnt a big deal for me either i just want to know its putting out the power its supposed to be. On 27" 589's mine will only do around 60 on a dirt road. never tried on pavement.
Old 11-02-2009, 11:51 PM
mrtwostroke's Avatar
my 05 800 stock tires, at 2500 feet. will only go about 62 mph. unless i'm down hill.
as far as I know it isn't hitting a rev limiter. so maybe a clutching change, or simply going to sea level maybe it would break 65 mph.
Old 11-03-2009, 06:27 AM
G.A.S.'s Avatar
with the stock 489's I would hit 70 mph on the speedo no problem. On GPS it was 67-68mph.
  #15
Old 11-03-2009, 07:01 AM
sammydogs64's Avatar
Originally Posted by Sport 500
Why would you want to go that fast? It looks like if speed was something you wanted, you would have got a sport bike.
SHUT UP, why does some META HEAD like you always poke his head in. If wants to go fast he bought the machine leave him alone.
  #16
Old 11-03-2009, 07:44 AM
Touring800's Avatar
Thanks for the responses everyone. Concerning the tire size questions I'm running 26" Mudlites. The tires are the only thing aftermarket on the quad. For everyones information I called my dealer about this and after he called Polaris he tells me the touring model has a lower gear ratio than the standard 800 since it's supposed to haul more weight. Apparently Polaris says the 2 up machines should be in the 55-60mph range and the standard 800 is in the 60-65mph range. I don't know that I believe his explanation. If the RZRS is rated by Polaris to run 63mph my machine should be able to do that easily. As for the questions about why I need to go that fast, well... it's my perogative. Actually I used to ride a Banshee years ago, so I still like to rip it up every once in a while. However, I needed a 2 up machine so I can leagally ride my 3yr old son with me according to the rules at a lot of parks. And just to squelch any other of subject replies, I'm obviously not pushing the machine that hard when he's riding with me.
  #17
Old 11-03-2009, 08:48 AM
Sport 500's Avatar
Thank you!! Were would I be without your leadership.
  #18
Old 11-03-2009, 10:35 AM
Mongrol's Avatar
"Official Site Skeptic"
Originally Posted by dcso3009
I must have an exceptionally fast machine. I was clocked by squad car radar at 78mph.
*edit*
The machine is a bone stock 07 with single exhaust FYI.
Were you hurt when your bike fell off that cliff?
  #19
Old 11-03-2009, 11:38 AM
IQSLEDNECK's Avatar
thats odd cuz with my 700 EFI acording to my spedo I can hit 72 mph running flat. but on the GPS it hit 68 mph. Is the 700 just as fast as the 800???
  #20
Old 11-03-2009, 04:58 PM
EPIChad's Avatar
I think for Polaris safety reasons the top speeds are usually about the same. But the 800 normally gets there a little faster.
Quick Reply: Sportsman 800 top speed?
