cooling fan
Old Nov 12, 2009 | 05:34 PM
aposto's Avatar
Default cooling fan
i have a 2000 sportsman 500.i need to order the cooling fan turn on switch. is it called the thermal switch. just dont want to order the wrong part. jump it out and the fan comes on.
Old Nov 12, 2009 | 06:19 PM
TLC's Avatar
TLC
If you jumped the fan and it works then the fan is not the problem, it will be a bad connection between the thermal switch and fan or the thermal switch itself.
If you splice your old thermal switch plug connection to a automotive thermal switch it will work. The switch from a 84-89 Nissan Maxama and a 86-89 Nissan Stansa will work.
I,m using a Blue Streak TS-127 right now. A Wells SW526 and Napa FS147 will do it also.
Thats if Your 2000 had a Polaris 4010161 switch.
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
