Anybody know what belt works with 2000 magnum with ebs and the 06 500 primary clutch
My new clutch # 1322555 has a 1/2" less diameter shaft in the center than my old one. Does anybody know what belt will work with this clutch? The 3211069 is too long at 40.875 and I don't know how much 1/2" diameter less equates to my belt legth.
The part # of the clutch you have was 06 and they used a 3211106 belt for the 800.
But if you go to 07 for the 800 they list two different secondarys using two different belts depending on which model of 800(AR, AL, AQ ect). One is a 3211113 and the other is 3211116. The 116 used the new rapid reaction roller clutch. I think the dimensions are the same just different type of belt. Now in 08 for the 800 they just used the 113 belt. Very confusing and what a mess for a dealer as to what belt to stock. Polaris needs a matrix on all the belts they have as to what they are.
Thanks kerbbirds, the 06 500 belt is longer than my current belt. It looks like I'm going to have to sell it. I talked with some that thought it would work on my 500 but the grooved drive is quite a bit bigger than the smooth one ebs to ebs and I can't find the right belt.
ULTIMAX® BY CARISLE CW1242-0064 $58
Here is a whole list of aftermarket belts.https://www.justatv.com/pages/atv_dr.../beltdrive.htm
