Scrambler 400 rear axle?
Old Nov 14, 2009 | 12:18 PM
nickmon3's Avatar
Default Scrambler 400 rear axle?
How do I remove the rear axle on a scrambler 400?
Old Nov 14, 2009 | 07:38 PM
lslubecki's Avatar
Support the rear of the quad. Remove the chain and caliper. From the right side: pull the wheel, remove the hub, remove the snap ring, remove the aluminum collar to expose the big jamb nut, remove the jamb nut, remove the sprocket assy., pull the axle out the left side.
Use lots of heat or spray lube on the jamb nut that is sure to be rusted solid. I used a cut-off disc to cut the nut then split the nut and removed it. Dont cut too deep or you will damage the axle. Use lots of Never-sieze on the axle and new nut.
Old Nov 14, 2009 | 09:26 PM
nickmon3's Avatar
Ok I will probably end up cutting the jab nut off because that thing is not moving at all
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
