Leaking gas out of carb when not in use
Old Nov 17, 2009 | 12:18 PM
polarisolsenho's Avatar
Default Leaking gas out of carb when not in use
My Polaris 2004-500 H.O. leaks gas out of carb. like you are pressing the gas constatly even when not using and just sitting there. Also at the very bottom of carb. there is a spout extending down that looks like it is missing a hose. Is this a breather hose or what. Leaks gas out of this spout to. What do you thing my proeblem is
Old Nov 17, 2009 | 12:21 PM
anyone there
Old Nov 17, 2009 | 12:56 PM
scootergptx's Avatar
Supersock
Hired Gun!
Not familiar with the petcock settings on that model. Don't think there is a P (primer) but if so, that could be your problem. Seems like mine just had on and off. May also want to check the float and make sure it's set properly.
Hopefully you'll get a response from someone who may have had, and solved this problem on theirs.
Supersock
Hired Gun!
And welcome to the forums.
Old Nov 17, 2009 | 12:58 PM
Supersock
Hired Gun!
Oh yeah, bottom hose you're missing is the drain tube if it's like mine. Should be a screw by that, check and make sure it's tight.
Old Nov 17, 2009 | 01:13 PM
Supersock
Hired Gun!
Did some checking and you just have on/off on the petcock valve.
Old Nov 17, 2009 | 02:26 PM
tw1st3d1's Avatar
Common problem with carbed Polaris machines. The needle and seat wears on them, replace the needle and seat, adjust the float, and issue resolved. Also will make it easier to start when cold, because the motor wont be flooded
Old Nov 18, 2009 | 06:47 AM
Kerbbirds's Avatar
Ditto on replace needle and seat, after you get it fixed start turning the gas off whenever its parked, needle and seat will last alot longer.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
