Glacier II plow any good??????
Old Nov 25, 2009 | 09:12 AM
eric88gt's Avatar
I too had a glacier 2 on my 700, and the mount bent very easily. I don't recall ever hitting anything with it, and at the end of winter there was a very noticeable bend in the mount plate. I now have a glacier 1 on my 800, and while it doesn't lift as high, i'm confident that i'll be able to use this one for longer than one winter without replacing parts....
Old Nov 27, 2009 | 06:50 PM
snosnake's Avatar
I have a G2 mount on my 550xp and it is very sturdy. I dont know what the mounts were like for non xp models they may be weaker.. I had a G1 on earlier bikes andd was very stout.but this g2 is even better.
Old Nov 28, 2009 | 02:06 PM
mtpockets's Avatar
My local Polaris dealer told me they have a bunch of new-and-improved Glacier 2 mounting plates on order. (currently on backorder)
Supposedly they are stronger than the current Glacier2 plates. I am waiting to look at one to judge it for myself.
I plowed last winter with the G2 on my Sportsman X2 and had the same trouble that almost everyone else had with the mounting plate bending. No newbie here, been plowing for decades.
I would highly advise that you avoid the G2 at this time.
Ever wonder why your local dealer has plenty of blades and angle brackets in stock but no mounting plates in stock for a Sportsman500 or X2? Think about it! LOL!
Old Nov 28, 2009 | 05:59 PM
RichiecNJ's Avatar
A few weeks back I picked up my Polaris with G2 mount and 60" Razor Blade, I soon got it back to the garage and to my surprise the bolt that mounts the bracket was broken off. (NEVER USED THE ATV YET) The bolt is supposed to be welded to the frame and you tighten it from the inside, the mechanic totally stripped the bolt from the inside and left the outside bolt loose! I'm going back to the dealer tomorrow to have a new plate mounted.. I was not very happy.
Secondly, When I have the blade down to the pavement the frame arms are nearly touching the pavement is this correct?
Old Nov 29, 2009 | 10:49 AM
  #15
mtpockets's Avatar
Yes the arms are very close.......and they will rub at times. Forgot about that 'till now! LOL!
I would like to know if the WARN Provantage arms are that close to.
Old Dec 9, 2009 | 11:57 AM
  #16
SaukFJ's Avatar
Default Weak Mounts for Glacier II
Had mine out in the snow for the first time today and like most others on the thread, it bent! Wish I would've read before buying. Lifts nice and high which is great for getting it on the trailer and backing out of deep snow, but they really need to beef it up.
Old Dec 9, 2009 | 02:10 PM
  #17
ScottM09's Avatar
Got to use mine for the first time today. Got about 10" of snow. Had some pretty good drifts across driveway. G2 plow worked great. Sure beats a shovel!
Old Dec 9, 2009 | 07:31 PM
  #18
FunRide's Avatar
Originally Posted by DCT
The Glacier II mount on my 08' 500 HO was a piece of crap. I bent it up like a pretzel after a few uses.Good luck
I got a Moose plow for my XP and bent it in half the first season. I've heard Polaris redesigned the Glacier II, but who knows.
Speaking of plows, my rig is in the garage sans tracks and plow and it just dumped a foot of snow in Maine. I've got to get a six pack and head out to the garage.
Old Dec 12, 2009 | 07:02 AM
  #19
Rubidude's Avatar
Are the blades bending on these or just the mounting plates? Where are they bending? Is it bending as a result of hitting something, or not backing before raising, or what?
Old Dec 12, 2009 | 09:22 AM
  #20
mtpockets's Avatar
YES, there is a newly re-designed Glacier II ATV mount. I just bought one yesterday and had it installed. Time will tell if it is strong or not.
I will be quite vocal if it's just as bad as the old G2 plate.
BTW, the new plate has a extra rib welded along the perimeter of the bottom of the plate. It's easy to see the difference between the two.
IF you guys are going to take a chance and buy the G2 set-up, just be sure to get the newly re-designed plate!
