00 sportsman 500 not charging
Yes its the reg/rectifier,check first that all connections are good. A lot of time one or more connections come loose. The red wire should have power at all times coming into the reg/rectifier,if does then in all probabilty just needs to be replaced,IF battery is good and can hold a charge in the first place. Should be charging 14-14.5 volts at battery.
bzdok1234
30
02-23-2016 01:55 PM
cody500ho
14
08-14-2015 05:03 PM
