'96 model magmum 425 has died.
Old Nov 29, 2009 | 09:50 AM
Nicahawk's Avatar
Default '96 model magmum 425 has died.
I put it in the shed for the night. Had been running OK. Next morning there was not a hint of even wanting to start. This a low mileage machine that has never been rode hard. Batt spins engine fine, fresh gas, changed the plug, fuel filters changed. Still not a hint of wanting to start.
I'm not sure what to ck next. Any help would be great. Thanks.
Old Nov 29, 2009 | 12:07 PM
Doctorturbo's Avatar
GOT BOOST!
You need to check the basics first.
Pull the plug and see if you have spark. Got spark? If not, you have a spark problem.
If so:
Give it a shot of ether and see if it runs. If it does, and them quits you have a fuel problem.
If it does not even try to pop on ether and you have good spark then take a compression test.
Do one at a time until you find the problem.
Old Nov 29, 2009 | 06:30 PM
ftwflh's Avatar
If you have fire at the plug check the valve clearance.This needs to be done on a regular basis any way
pgamboa
Dec 24, 2023 11:52 AM
Mar 21, 2016 06:30 PM
Whitelx1
Oct 2, 2015 10:55 PM
Steeldon
Sep 9, 2015 09:38 AM
