2000 scrambler 400
Old Nov 30, 2009 | 11:26 AM
GIGEM18's Avatar
Default 2000 scrambler 400
I was riding yesterday and the atv started making a wining noise when you take off. Sounds like bad bearings, but i dont know. I wanted to check trans fluid but dont know were the dipstick is. And is there a drain so i can just change the fluid.
Thanks in advance
Old Dec 1, 2009 | 08:47 PM
Drain plug on left side of gearcase close to bottom,fill plug bolt on right side top behind floorboard. Fill with AGL to bottom of threads in case. Whining noise could be from bearings or chain needs to be adjusted OPT Ingleside huh? Hope you'r house is on stilts!! At least no hurricanes this season. Have an old high school friend that lives there now.
Old Dec 2, 2009 | 08:42 AM
GIGEM18's Avatar
what is agl. we have been getting alot of rain but were i am it is all sand and is no standing water. other people are not so lucky. thanks for the advice.
Old Dec 2, 2009 | 04:55 PM
4getful2's Avatar
gearlube ,like differential lube. 75w-90 or straight 90
Old Dec 2, 2009 | 05:27 PM
ftwflh's Avatar
This is totally wrong!You use a chaincase lube in the tranny.These are chain driven not gear driven and need proper oiling
Old Dec 2, 2009 | 05:51 PM
Kerbbirds's Avatar
Agl is polaris oil for tranny, it is a thin oil, like motor oil, do not use 80 - 90, I use 5-30 synthetic in mine , other people dont like this but I have alot of miles on mine several others that I service and they are doing fine, 5w-30 Castrol synthetic, engine and tranny, 6000 miles, no troubles.
Old Dec 2, 2009 | 11:09 PM
GIGEM18's Avatar
thanks guys
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
