sportsman 400with vamp problem
Old Feb 24, 2001 | 03:18 PM
POLARRIDER's Avatar
I have a 95 sportsman 400 4x4 2-stroke. I want to run 26x9.5-12 and 26x12-10 vamps. I do a lot of trail riding but when i do get to the mud i wanna be able to hit it good. Also any have experience with spider tracs. 26"size. Will ihave enough power to run the 26" vamps or would i have to drop down to 25" I have a aaen pipe ordered so that should help
Old Feb 24, 2001 | 03:29 PM
Thor's Avatar
Good grief
Old Feb 24, 2001 | 07:10 PM
Lurch77's Avatar
What kind of reply was that?
You should not have any problems running the larger tires with your engine. When you add the pipe don't forget to reclutch too. This will help alot with the larger heavier tires.
Old Feb 24, 2001 | 10:54 PM
Farmr123's Avatar
Don't worry, the 400 2 cycle has plenty of power to turn bigger tires.
Old Feb 26, 2001 | 04:30 PM
CajunDuckman's Avatar
The key is to not run 12" wide Vamps in the front. You will blow a cv every other time you ride. Other than that you can go with 27" if you put a lift on it. 26's will go with no lift.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
PolarisPower500
May 17, 2015 02:28 PM
Muddog1
Jan 12, 2001 10:12 PM
