Exploding oil tank 07 X2 500
Old Feb 15, 2010 | 09:37 PM
ramman67's Avatar
Default vent
there should be a slit in the vent hose about 2 or 3 inches from the oil tank that should open up if there is a blockage in the vent line.but for some reason yours didnt open and built up way to much pressure.
Old Feb 15, 2010 | 10:05 PM
MECHANIKE's Avatar
thats freakin awful!!!!!!!!! go on ebay and pick up the alum. tanks, i can't possibly see any problem switching,same motor same stupid system.i leave mine outside in 8 degree weather tons of times lately, no boom!!!hence alum. tank...........
Old Jan 4, 2011 | 01:47 PM
UpNorthFam's Avatar
Just had this happen to my 2004 500 atp, Vent tube Huh? What a crummy design.
Old Jan 4, 2011 | 02:24 PM
MECHANIKE's Avatar
pick up an alum. tank only tons on ebay,,,,,,,,,,,,,
Old Jan 4, 2011 | 02:25 PM
  #15
TLC's Avatar
TLC
If you find a older alloy tank it should work, the 500 motor has never really changed at all.
The alloy tanks are not just stronger but also have cooling fins,to make the oil tank act as a oil cooler.
Old Jan 4, 2011 | 02:54 PM
  #16
x2 bum's Avatar
On my first oil change I discovered the plastic tank and was not enthused. I looked at the alloy tanks and like the added strength and cooling effect. It would be nice to know if someone has done this and if the older model would bolt right up. If it does, how hard is it to change the oil. It seems on the x2 you would lose access to the dipstick.
Old Jan 4, 2011 | 05:54 PM
  #17
marc340's Avatar
we see that more around here i am in canada ,the best way to make shure it won t hapen again its to do real ride not just stop and go ,and if you plow or play in the snow next time you start your atv slack the dipstick until its hot.
Old Jan 4, 2011 | 06:22 PM
  #18
MECHANIKE's Avatar
hey TLC there's another one for your sig. NO PLASTIC OIL RESERVOIR!!
Old Jan 5, 2011 | 02:26 PM
  #19
NoJoke's Avatar
Howdy all.......OK, lets say that that the plastic oil tank is replaced by the stronger aluminum tank......what will be the next "weakest link" to fail......the pressure that was bursting the plastic tank still needs to be dealt with.....it's gotta go somewhere.....NoJoke
Old Jan 5, 2011 | 02:45 PM
  #20
reecejack1's Avatar
True, the pressure that made the tank explode could for sure do damage to something else
