Scrambler 400 no start +backfire. Ran fine,sat in cold 1 week,almost started....
Old Dec 21, 2009 | 01:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that is good compression. if you have water on the plug then you have a big issue for sure. next would be a leak down test to see if theres a head gasket gone. imo.
Old Dec 21, 2009 | 04:15 PM
thefed's Avatar
a leakdown test is when you pump IN compressed air? yes? same concept? some kind of spark plug adapter?
it did hold at 110-115 psi for about 15 minutes when i came in to post
I dont know if there's water on the plug, but there is excessive smoke. however, LAST winter i posted the same thing about the smoke....is this a result of the tuning and cold weather perhaps? running rich? smells rich, not entirely like antifreeze.
Old Dec 21, 2009 | 07:39 PM
Doctorturbo's Avatar
GOT BOOST!
I have bad news for you. The coolant system is a closed system. If it's not leaking on the ground and it is going somewhere; where do you think it's going?
Yep, it's getting in the engine for some reason.
IMHO just pop the head and jug off and replace the gaskets. It will be as quick or quicker than doing a leakdown.
With a few bucks and a little time you will be back on the trail in no time.
Old Dec 24, 2009 | 11:34 AM
thefed's Avatar
I've never done this on an atv before...done head gasket on a chevy 350 though!
anywhere to find a writeup/how-to on doing this? how long should it take, in reality?
Old Dec 24, 2009 | 12:41 PM
  #15
nickmon3's Avatar
Excessive white smoke means you are probably burining coolant and have a head gasket leak.
Old Dec 24, 2009 | 01:39 PM
  #16
tv4fish's Avatar
Agreed ! (You haven't said if you tried a NEW plug yet?)
Old Dec 24, 2009 | 04:45 PM
  #17
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
You may want to check your stick on the counter balancer, you indicated excessive "White" smoke. If the stick has a Milky texture to it, seal is going
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
clsharky
Jun 8, 2015 11:38 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
