850xp plowing
Old Dec 20, 2009 | 04:27 PM
rr-john's Avatar
Default 850xp plowing
why does the plow frame scrape on the ground when you back up or just plow i stiffen the front shocks all the way doesnt work. does this happen to everybody or just me and what else can i do
Old Dec 20, 2009 | 06:12 PM
DCT's Avatar
DCT
Banned
You may have the blade angled back at the top too much, causing the blade at the ground to be angled out too much, which will lower the push tube.
Try this... with the plow attached to the quad on a level surface, drop the blade to the ground. Then, adjust the skids all the way up so the blade is touching the ground... or as close as possible.
Then, stand along side the blade and see if it is straight up and down (or just slightly tilted back at the top). Adjust it with the oblong bolts that attach the blade to the push tube until the blade is straight. When you've got it like you want, adjust the skids down so the blade is just off the ground.
Let me know if it works out for you.
Old Dec 20, 2009 | 06:21 PM
TheATVSuperStore.com's Avatar
Former Sponsor
I have noticed the same issue. With my SP800 it the G2 was fine but with the XP the G2 rubs. Seams like they should have made the push mount several inches shorter. I also made the pull bar shorter so the blade will lift higher.
Old Dec 20, 2009 | 07:12 PM
noooooo's Avatar
Nice looking rig Thor. The massive 1/2" snow storm wasnt quite enough to break out the G2 xp plow yet. Trust me I would love to be able to chime in with a relevant answer. I am selling mine to my uncle once I use it to see how the 850 handles a 72" blade.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore
Sep 9, 2015 07:43 PM
