1989 trail boss problem cold start
Old Dec 28, 2009 | 01:10 PM
beninlou's Avatar
Default 1989 trail boss problem cold start
i just picked up an 89 trail boss when cold theres no start i could put space heater beside the atv for few minutes and it would start and 99% of the time run good but then sometimes would spit and sputter and back fire.took.checked it out today while it was still cold pulled the plug and no fire.took hair dryer to the coil for about 30 seconds and had good fire and atv started right up.should i just go ahead and replace coil or could something else be causing this?thanks ahead of time without these forums i would be lost
Old Dec 28, 2009 | 05:57 PM
ftwflh's Avatar
Check the cold compression it needs to be very least 100psi better if 120psi
Old Dec 28, 2009 | 06:47 PM
beninlou's Avatar
even if the compression was low the plug would still be firing i would think
Old Dec 28, 2009 | 09:53 PM
ftwflh's Avatar
True but I would still check it.Most likly problem would be a CDI or Stator problem
Old Dec 29, 2009 | 04:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
also check for good connections and no corrsion.
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
Rod
Oct 4, 1999 12:37 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
