Top end assembly ??????
Old Jan 5, 2010 | 05:53 PM
firemedicsafd's Avatar
Default Top end assembly ??????
When i put my top end back together for my 97 scrambler bored .40 over with new piston and rings, is there any assembly lube i should use to protect the cylinder from scratches? Any other helpful hints on the top end rebuild would be appreiated also. Thank you!
Old Jan 6, 2010 | 05:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes it wouldn't hurt anything to be use a good preassembly lube. make sure the rings are set correctly and piston is facing right direction. imo
Old Jan 6, 2010 | 07:23 PM
4getful2's Avatar
don't laugh, but i used 2 stroke oil as assembly lube when i put my 400 2 stroke back together
Old Jan 6, 2010 | 07:45 PM
Thats fine! thats what it uses any way and its usually what I coat a 2-stroke cylinder with on rebuilds. OPT
Old Jan 7, 2010 | 05:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Jan 11, 2010 | 06:41 PM
How can you tell which direction is " Correct" on a aftermarket piston?
Old Jan 11, 2010 | 09:19 PM
eggenz7's Avatar
markings either go to magneto side or exhuast side. just depends on where the markings are
Old Jan 11, 2010 | 09:29 PM
Wenty's Avatar
Isn't there a arrow or line on the top of the piston? If so, the arrow or line faces forward.
If not...the manufacturer should have given instructions on proper placement.
Old Jan 24, 2010 | 07:12 PM
i figured it out...hopefully. The intake values are bigger than exhaust...so the cuts in the piston are bigger also. I read the instructions and the service manual, they stated that the arrows or dots face the exhaust but that put the piston perpendicular to the wrist pin mount. So i figured it out the valve clearance way.
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
slowgsxr97
Sep 8, 2015 04:37 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
mbkirk
Aug 14, 2015 08:20 PM
