ITP TerraCross R/T on XP
#21
#23
#24
Here is what mine measured when I was done. This was from outside edge to outside edge IIRC,this is the width I needed for Big Horns. The XTRs required a little less of a bend. What I suggest is doing it with the tires mounted and bend a little at a time until you get the clearance you want. As mentioned above once you bend it so much it will hit the exhaust/heat shield when you try to rotate it back foward. If you need that much of a bend you may have to take the sway bar mounts off to get it back in position.
#30
I just got the tires & wheels mounted. I took the XP for a spin around the property & did notice she is wider now. She did not fit in the prior tracks all the way. I did notice that it feels more stabil on the road. I will get you more feedback this week when I go for a longer ride. Here is a pictures I just took. I love the looks of the new wheels and tires. Sorry for the picture quality its getting dark out now.
