Plowing hard on transmission?
Chances are it's the seal on the shifter housing. Factory puts a lame bead of silicone and it is prone to leaking which binds up shifting when it's cold out. I pulled mine apart and also found it was missing an o-ring seal on one of the two shafts. Replaced that and sealed it up with anaerobic schmoo(expensive but awesome stuff). After that it shifts smooth as silk even when it was double digits below zero.
I just went through this on my 700. The linkage needed adjustment but also found inside the plastic case that it was frozen solid in there...pulled apart, thawed it out, filled with grease and siliconed the snot out of it and like butter ever since....
Elkaholic
Sep 6, 2015 02:44 PM
