bypassing my 06 polaris 450 stator
Old Jan 29, 2010 | 07:37 PM
xcovelectric's Avatar
Default bypassing my 06 polaris 450 stator
When I bypass my 450 polaris stator my bike will run just fine but when I plug in the three yellow stator wire connection my bike will die I put a new CDI and polaris put a new ECM under warrenty a new COIL-PULSER, IGNITION COIL and a Stator off of a 06 polaris with little hours off of ebay. The bike would cut off with the old stator now its doing the same thing with the newer stator. If you plug in the yellow stator wires and put the plug on the frame the plug will fire 5 times,What do I have going on?
Old Jan 30, 2010 | 06:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what color is the ecm they replaced? caper actually went 3 of the replacement ecm's before he had his 450 straighten out. just a thought.
Old Jan 30, 2010 | 09:38 AM
Default About my stator
The ECM is silver and it says made in usa,I swaped the ECM with my brothers ECM on his 500 and its doing the sale thing so I know its not the ECM. I really appreciate the help it has me scratching my head. I also found out if I pull the plug and look for spark I will have five sparks with the stator wires hooked up. If I let off the key and try to turn it over it will have no spark until you put the key back to the off position and start it again. Im gonna try to swap the ignition with my brothers 500 and see if that helps.
Old Jan 30, 2010 | 04:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that does sound strange. ya if it's the new silver one then its the new style. good luck.
Old Jan 30, 2010 | 08:40 PM
Smile about my polaris 450
Well i fixed the problem,it turned out it was a bad battery or a corroded connection on the starter selonide. I was using a big battery charger to start the 4wheeler and also I took the starter selonide off and cleaned all the connections.
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 13, 2015 05:11 PM
Shifts
14
Jul 13, 2015 08:41 AM
