No AWD - Bad Speedometer
Old Jan 30, 2010 | 07:08 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default No AWD - Bad Speedometer
Speedometer does not work and neither does the AWD. Scanned this site for alternatives and tried them (I grounded the brown / white wire and then I tried splicing the brown and brown/white wire) and still no AWD. THis worked for alot of folks with 200 Sportsmans but no mine?
Only other thing I can think of is ...will an extreemly week battery keep the front wheels from engaging?
Please help
Old Jan 30, 2010 | 11:35 PM
bentarrow's Avatar
First Things First!
Weak battery will do a lot more than that, but yes that and the speedo and reverse override. Check your battery voltage, maybe switch the battery from the other 500.
Old Jan 31, 2010 | 06:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed check to see if your batery is getting any charge from the bike. it needs a good 12 volt charge to keep things working.
Old Jan 31, 2010 | 12:17 PM
weedy's Avatar
Battery will be replaced and I will try bypassing the speedometer again.
Is grounding the brown and white wire the best method?
OR
Is splicing the brown and white wire with the brown wire the best method?
Old Jan 31, 2010 | 12:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think i have read gronding the wire is the best way but can't be 100% sure. you still should be able to test your charging system to make sure it is putting out voltage w/out buying a new battery by using a tester while it's running. imo
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
400H0
10
Aug 20, 2015 07:34 PM
chuck1177
Jun 30, 2015 09:52 AM
nevermiss
Apr 1, 2000 10:53 AM
