studing tires ???
Old Feb 8, 2010 | 04:49 PM
rr-john's Avatar
Default studing tires ???
if i put studs in my tires and then take them out in the spring time are the tires junk or still good
Old Feb 8, 2010 | 05:56 PM
muddynoodle's Avatar
Default stud tires
good question new xp owner like to know toooo
Old Feb 8, 2010 | 06:11 PM
HighVelocity's Avatar
I've got close to 500 screw-in carbide studs in total in the ITP 589's on my 2010 850. Choose the correct thread length, so you don't screw right into the carcass of the tire and you'll be fine. I used 3/4" and the lugs on my tires are a little over an inch. I'll be pulling them out in a couple months and don't foresee anym issues.
Old Feb 8, 2010 | 06:40 PM
richard_2010's Avatar
Highvelocity is right, if you pick the right studs for your tread depth you won't have any problem at all. You can even order them online www.maxigripstore.com. They sells carbide studs that you can reuse for more than one season.
Easy to fit in, easy to remove.
Old Feb 8, 2010 | 08:07 PM
switzomatic's Avatar
Double check to make sure it's legal to run with them on the trails in your area if not on private property too. Some states are sticklers on that stuff.
Old Feb 9, 2010 | 03:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i have known people to do it w/ no issues. as mentioned above the right size screw makes all the differnce.
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
