charging problem
Old Feb 10, 2010 | 04:00 PM
allis3300's Avatar
Default charging problem
went out today to plow on my 2003 500HO sportsman. fourwheeler started right up. half way through plowing the battery light started to flash on dashboard. stopped plowing and charged the battery. went back out and about 5 minutes the battery light started flashing again. need to know where to look for problem, if anybody can help.
Old Feb 10, 2010 | 04:58 PM
MECHANIKE's Avatar
hi, how long did you charge for? if you have a meter see what the votage is running,13.8-14.5 volts is good, need battery. if its 12,no charge.
Old Feb 10, 2010 | 05:32 PM
allis3300's Avatar
when running it is 12. what should i check next? taking battery to auto parts to have tested.
Old Feb 10, 2010 | 05:54 PM
94harley's Avatar
See if the voltage regulator came unplugged.
Old Feb 10, 2010 | 05:55 PM
MECHANIKE's Avatar
yeah somethings out in the charging system,you probably notice no increase in brightness when you give it alittle gas,still cheak batt cause discharge is hard on the batt,clean and tighten all connections...............
Old Feb 14, 2010 | 02:49 PM
allis3300's Avatar
today i finally got back out to the barn to work on fourwheeler. i put the old battery back in and started fourwheeler, then disconnected the negative side of battery and the fourwheeler sat there and ran just fine. a guy i work with said to try running fourwheeler with battery disconnected, after starting. battery seems bad and have a new one coming on monday.
Old Feb 14, 2010 | 02:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i wouldn't recommend running that bike w/ out the battery hooked up or you could damage the charging system. imo
Old Feb 15, 2010 | 07:30 AM
Kerbbirds's Avatar
When running at 2000 rpm or so should show 13.5 or more volts if charging correctly, if not its probably the regulator located in front of radiator , left side, square box with wires coming out .Battery should show 12 or more volts with machine off, if not battery is bad.
Old Feb 26, 2010 | 03:06 PM
allis3300's Avatar
The problem has come back. I need to know how to check the regulator. If anybody could help. I checked on partsland and they show that part obselete and no longer available. But I did find a replacement at ronnies.
Old Feb 26, 2010 | 06:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most likely check the connections to see if it came unplugged or is corroded.
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
hondarider1234
Jul 21, 2015 11:53 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
