03 magnum 330, loading up on fuel???
Old Feb 14, 2010 | 10:25 AM
chevyaddict83's Avatar
Default 03 magnum 330, loading up on fuel???
Went riding last night, and on the first long straight trail i hit, she was held damn near wide open. After about 20 seconds of that, it started bogging down, and backfiring. Going through trails, she ran like a top. But on the long straights near W.F.O she didn't want anything to do with it. /i would let it sit for about 10-15 seconds and it would fire back up. It seems like it's getting too much fuel. Any Idea's guys?
Old Feb 14, 2010 | 10:56 AM
Might not be getting enough fuel on long runs (starving,bogging down) check fuel filter,also you can check flow at carb by disconecting fuel line and cranking over,should be a fairly good stream. Check the vacuum line leading to carb also. Also have found trash in a few needle valves over the years that limit flow. Or could be diaphram/slide in carb. Might help,dont know??? OPT
Old Feb 14, 2010 | 02:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it does sound like on top end where you said it was back firing that it was running lean cause of what he ^^^ mentioned. how did the plug look after the wot run?
Old Feb 14, 2010 | 07:00 PM
I havent pulled the plug yet. I am going to be lazy about it, and run some lucas through it. It just blows my mind that it is so out of the blue.
Old Feb 15, 2010 | 07:17 AM
Kerbbirds's Avatar
Jets in carb maybe partly plugged.
Old Feb 15, 2010 | 09:47 AM
Thats what i am hoping for. I just got this 4 wheeler 2-3 months ago, and it was running rough. I have been running lucas in my gas and up until i stopped, which was one tank ago, it has been great, so i am gonna try a little more today
rawbdiggity
34
Sep 2, 2015 02:16 AM
bradco
Aug 21, 2015 08:11 PM
mattcraig1
Aug 19, 2015 03:48 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
