i've got the sickness........................BAD
Old Feb 14, 2010 | 09:13 PM
MECHANIKE's Avatar
10/4 Rtickwad,like said i need to drive one around abit,dually noted...............
Old Feb 15, 2010 | 06:04 AM
ftwflh's Avatar
I get into the same situation at times.Redoing a 96 400L Sportsman right now that I got to part out.
The 250 Trailblazers are a blast put a pipe and clutching and it runs with the 300/350 import sport machines.Add few more $$$$$ and they will run with the 400s
Old Feb 15, 2010 | 07:58 AM
MECHANIKE's Avatar
rity-o on don't tell the wife, luckely i don't have a "BAG WITH A HOLE IN IT".so i have money movement.so ftwflh so you can get alot outta a 250??? i'm glad to hear that cause,its suppost to of been rebuilt 40 hours ago.i want to put heavier weights cause you can hit the gas alittle before it stats to move at all.pm me if you come across anything that will spice this thing up,i know 2strokes start better in 10 degree weather,cause it don't have that thickened oil to spin around in the crankcase.................
