polairs
Old Feb 13, 2010 | 04:48 PM
riverrat2u2's Avatar
Default polairs
02 polairs 700 will not crank just clicks do they have a neutral switch
Old Feb 13, 2010 | 04:52 PM
xplorerman's Avatar
yes but if it is clicking check battery (voltage) solenoid, starter and wiring
Old Feb 13, 2010 | 07:35 PM
700 sportsman's Avatar
if it is clicking, I would say your starter solenoid is shot, you need to check to check to see if you have voltage on the battery side of the solenoid, and then while attempting to start it, see if you have voltage on the other side.
That's my guess, also do some searching, there has been several threads about these types of issues
Old Feb 14, 2010 | 02:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure batt. is 100% charged and then w/ key in the on postion, jump the 2 big solenoid wires and if it still clicks it's the starter that has issues and not the solenoid and if it does fire up then you know it's the solenoid that is bad.
Old Feb 14, 2010 | 08:20 PM
Default Starter
Doe's the starter come out with the drive .
Old Feb 14, 2010 | 09:45 PM
FunRide's Avatar
Sten, You've got a pretty amazing array of experience with these machines. I can only figure, lots of messing around with various rigs.
Old Feb 15, 2010 | 04:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
na, just dumb luck did check to see if the starter will engage?
Old Feb 15, 2010 | 08:03 AM
Default Polaris Starter
I've been stupid with this POS , will the starter motor come out without removeing the side cover , I should have checked the starter firdt thing.
Jordanatv
Utility ATVs
Feb 18, 2015 10:35 AM
mud moose
Feb 20, 2009 10:14 PM
oaklandr8ersfan
Sport Quads
21
Mar 12, 2007 03:20 PM
jlm9r
Jul 31, 2006 06:54 PM
upssmann
Mar 13, 2005 04:59 AM
