1997express 400 rebuild project
Old Feb 28, 2010 | 09:01 AM
hummer3d's Avatar
Default 1997express 400 rebuild project
just got finished rebuilding 400 motor. did new rings seals and gaskets.
im readey to reinstall into bike.
now for the questions.........
1 Do i need a batery on the bike to start it? It didnt have batery when i got it.
2 i need a batery to run fan on radiator correct.?
3 what oil does the transmision use? i want to change its oil? How much oil goes back in? The transmision came out of my 95 polaris 400 2x4 parts bike. I got as a rolling frame motor trans and rear swing and axle fit my experess also.
4 i unhooked Oiler . planing on mixing my gas and oil myself. I was thinking an mixing 20 to 1 on first tank does this sound ok? I was planing on buying Bell Ray 2 cycle oil .
Ok thats all my questions for now. Thanks for all the help and advice you guys have been providing me. This site is a great place to be . Thanks to all!
Old Feb 28, 2010 | 11:51 AM
94harley's Avatar
You don't need a battery to start it, BUT, you should have a good battery in it anyway. Theres an issue with the way they charge on older machines and without a good battery you can have several electrical issues down the road(some of the issues can keep the motor from running too. My advice, put a battery in it.
The trans uses Polaris AGL. I think it around 19 oz.
20 to 1 will be fine for breaking it in. You may foul a plug or two.
Old Feb 28, 2010 | 12:32 PM
ftwflh's Avatar
40:1 is what you need to premix.I would leave the injector system on.It is very reliable and you get the oil you need when you need it.
Old Feb 28, 2010 | 08:51 PM
hummer3d's Avatar
well I got the motor in this afternoon . Test fired it. I found out it does have spark . Now I need to flush fuel tank and get it and the exhaust put back on for more testing. I also need to flush radiator and refill it too. It looks like its all comeing together. I just wish I could skip work tommarow and finish
I choose not to use auto oiler due to not knowing if it failed and seized the last motor on the express. I also didnt want to take chance and trust it. Id rather just mix my gas and know I dont need to wory about it. Im sure they normaly work great but ,dont feel like trying to adjust it since it got takin off during motor rebuild.
I just need to get me a batery, polaris agl for trans and some good 2 cycle oil this week. I cant wait till my next day off!
Old Mar 1, 2010 | 05:09 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would recommend putting a battery in as harley stated and to run the fan, lights and what not a battery is a must.
Old Mar 1, 2010 | 08:44 PM
hummer3d's Avatar
im shopping for a good batery this week. I found a $50.00 and$75.00 ones at wally word,but want to check Interstae bateries also. any sugesstions an where to get the best batery for my money? Thanks
Old Mar 1, 2010 | 09:36 PM
MECHANIKE's Avatar
PAID $29 LAST TIME I GOT ONE AT WALLYWORLD,I THINK THERE IS A REASONAble one on ebay i'll check........
Old Mar 2, 2010 | 08:51 PM
hummer3d's Avatar
I got my batery today. i picked up a batery from Atwoods Ranch Store. It was $39.oo.. I cant wait till my next day off.
Old Mar 6, 2010 | 09:48 AM
hummer3d's Avatar
Smile
Help! I got allmost every thing back on . I charged my new batery and hooked it up. Treid to start with starter , but all i get is a click when i hit strart button at the positive Batery cable solinoid. I have cleaned all cable ends so far except the one on the starter. Is there a lock nut on the starter cable stud?.I cant tell it looks very rusted. I turned the nut and whole cable moves . I think this is the problem but not sure.
Also the batery is new i filled with acid as the instrucions said, They said somthing about after charging ,batery should gas freely And specific gravity should be around 1.282 for 12 volts. How do i check this ?
I charged the batery with a brand new black and decker charger at 2amps. But charger only charged for about 2 hours before it kicked off to full charge . This seems like it would need more charge to me.
So far i know i have spark with key and run switch on. I know i have no spark with run switch off, so kill switch works I can get it to fire gas i put in spark plug hole. I injured my left elbow tryng to start it with rope starter before i had batery hooked up.
What does the yellow overide button do by kill switch?
Thanks again.
Old Mar 6, 2010 | 10:04 AM
bitterfitter's Avatar
the override button takes the reverse rev limiter out of the picture when backing up, so you can have full power in reverse. It's a lawyer button.
