1998 Polaris 300 explorer
Old Mar 3, 2010 | 01:27 PM
cragle1's Avatar
Talking 1998 Polaris 300 explorer
I have a 1998 Polaris Explorer. It will not start. It has spark but very weak. I'm thinking a
stator coil. How can I test it as I don't have a repair manual? I've tested artic cats and ect but no schematics on the polaris
Old Mar 3, 2010 | 10:54 PM
ctdnwakulla's Avatar
Check your secondary ignition first. Make sure you have a good ground at the coil. The plug cap removed from the plug wire should have approx 3.7k-6.3k ohms. Input at coil to end of plug wire 6.3k ohms (with cap removed). The cap on my 400L was open so I replaced the wire and cap at the same time. They can be unscrewed counterclockwise, and were very reasonable at the dealer. Under $10.
Old Mar 4, 2010 | 11:05 AM
cragle1's Avatar
I removed the coil and cleaned it up. My test on the plug cap showed 10.68 ohms and on the coil I had 6.4 ohms. Is the resistance on the cap too high?
Old Mar 4, 2010 | 10:18 PM
Make sure that your ohm meter is set on the K ohm setting or if is auto range be sure that its reading the correct range. If the cap is 10.68 k ohms,yes that is too high. If the coil and wire are 6.4 k ohms, that is acceptable. 6.4 ohms and 6.4 k ohms are a world apart. Hope the cap fixes your problem, inexpensive fix.
Ramman1
Aug 11, 2022 01:53 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
