Alignment question
Old Mar 12, 2010 | 05:49 AM
09 popo HO's Avatar
Personally the string method didn't work well for me. Seemed to have too much room for error.
My polaris shop manual suggests the chalk method.
Mark a chalk line on the inside of each tire (at the hub height).
Measure the distance between the chalk marks. Roll the quad forward so the chalk marks are at the rear on both tires (at the hub height again). Measure between the chalk marks again.
The rearward measurement should be 1/8 to 1/4 less then the measurement in front.
Also recommend strapping the bars so they stay straight the whole time as mentioned above.
Old Mar 12, 2010 | 11:25 AM
FunRide's Avatar
Might be worth making sure the tires have the correct pressure, with the fronts matching pressure and the rear matching pressure for most accuracy.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
