rev limiter????????????
Old Mar 20, 2010 | 06:37 PM
hummer3d's Avatar
Default rev limiter????????????
Where is the rev limiter located on my 97 express 400? I want to test it as im still having problems with geting my new rebuilt 400 to run correctly. it seems no mater what i do i can't get it adjusted with good idle and have it even be able to rev up. i think there must be some other electrical problems maybe etc solinoid? if while giving it gas i push solinoid in it revs a little better. what does this solinoid do anyway? also ive read other threads with carb motor runing issues where they say remove the black wire of the rev limiter to see if things improve. Is it on the front left hand bottom of the wire plug block? I want to make sure before i try removing the Black wire.
Thanks
Old Mar 20, 2010 | 07:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
here it is. number 33#
http://parts.polarisind.com/Assemblies.asp
go figure damn thing wouldn't come up. anyways go on the left side and find electrial and c lick it and find number #33
Old Mar 20, 2010 | 07:31 PM
hummer3d's Avatar
ok thanks it is the part i thought , so i will unplug black wire and see if it has any affect on the poor rev.
Old Mar 21, 2010 | 05:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
your welcome. hopefully you will get in straighten out.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
