found out why my high beam dont work? no its not the bulb!!!
Old Mar 27, 2010 | 10:52 PM
chuck_raduenz's Avatar
fixed it today. heres the before pic:
Old Mar 28, 2010 | 06:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well at least you got it fixed and now no more worries about that problem. good deal
Old Mar 28, 2010 | 09:33 PM
your telling me. it wasnt the fixing part that was a pain. it was removing everything to get to it....
you know what they say "the only way you know its done right. is to do it your self"
all polaris had to do was route the wires though the top of the harness. then it would have been fine. but now im looking for a high beam head light plug so i can fix that also. last winter when i was trying to replace the headlight bulb i broke off one tab. but it was a 20deg day. plus there are also cracks in the wires near the base of the plug. i found the plug for $2 and its a little bit shorter. im just trying to figure out if it is the correct one. i also added dielectic grease to my plugs becuse they were starting to corode and turn green.
Last edited by chuck_raduenz; Mar 28, 2010 at 09:46 PM. Reason: spelling and added
Old Mar 29, 2010 | 05:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
good luck w/ it chuck.
Old Apr 17, 2010 | 12:44 AM
  #15
ranchrocket's Avatar
I've got both an '08 and '09 500 EFI. Both of them have broken the wires to the high beam headlight. The '09 three times and the '08 twice. Both are currently not working. Does anyone have a re-routing solution or something to keep them working? It's getting frustrating having them break all the time. The '09 even pulled the yellow wire apart that goes to the key switch. My '06 450 never did this and it had almost 8000 miles on it when I traded it off.
Old Apr 17, 2010 | 04:50 AM
  #16
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like chuck figured a way to reroute maybe. i bet it's not easy to do for sure.
Old Apr 18, 2010 | 12:18 PM
  #17
i ran mine though the top of the harness and gave it more slack. hopefully this will work. if not im gona have to firgure out another way. been working so far.
Old Aug 27, 2010 | 05:03 PM
  #18
dbradicich's Avatar
Default 2007 High Beam Ligh - Same Issue
good call! check the wires coming out of the protetive wrap,, basially the chaffing of the plastic covering cut right through the yellow wire,, .. Pulled all that out of there , made a new connection and tied it back together with a little more finesse. and Voila. its a fix
Old Aug 27, 2010 | 06:37 PM
  #19
Fishy MN's Avatar
Dbradicich, Welcome to Atv Connection, Glad you got it taken care of.
Old Aug 27, 2010 | 06:40 PM
  #20
stendori's Avatar
Super Quad Patrol
I'm watching you!
and another happy member from a great forum, and welcome also.
txkevin
Sep 21, 2015 02:02 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Land_shark1
Jul 10, 2015 12:53 AM
Trade3
Ask the Editor
Jun 21, 2015 10:30 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
