07 predator oil and jet recommendations
Old Mar 28, 2010 | 07:50 AM
outlander 1's Avatar
Default 07 predator oil and jet recommendations
hi all, i just bought a 07 predator 500 and i was wondering what oil to use in it, also it has a hmf preformance pipe on it. i want to check if it was jetted correctly, what jet is stock and what jet should be on there with this hmf pipe?? also with this pipe will my gas comsumption be alot more...thanks
Old Apr 4, 2010 | 08:49 AM
CCPAPreddy's Avatar
Hi,
I see no one responded to you. Usually, the site is pretty friendly. As a fellow Predator owner, let me se if I can help.
I do not know the factory numbers on the jets, but I am sure there is a site that will tell you. Also, you can check the site of the pipe manufactorer, see what they recommend and compare to what is in your bike now.
Alos, what you can do to see if the jetting is correct is to read the plug. You will need to install a new plug, then run the bike a half to three quarter throttle for several minutes of riding. You then chop the throttle and shut it off immediately. (this takes the idle circuit out of the test, as you want to read the plug while using the primary jet) The plug should look tan in color. If it is white, then you are too lean. If it is black, then too rich.
Hope this helps. Good luck.
Old Apr 4, 2010 | 08:52 AM
CCPAPreddy's Avatar
Gas consumption, if jetted properly, should not be adversely effected.
Old Apr 4, 2010 | 09:39 AM
thanks so much, but what do u mean by chop the throttle?
Old Apr 4, 2010 | 04:21 PM
MiNuS...'s Avatar
What is jetting?...
Old Apr 5, 2010 | 08:55 PM
CCPAPreddy's Avatar
Chop the throttle, you would be going and in an instant, let the engine go back to idle, and then shut it off. Pull in the clutch, let your finger literally slip off the thumb lever, engine then is back to idle as quickly as the RPMs will drop down,.
wendal
Sep 7, 2019 06:46 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
kampswas
Sep 23, 2015 05:05 AM
Elkaholic
Sep 6, 2015 02:44 PM
Brandon400
Sep 5, 2015 08:44 PM
