Carb help needed.
Old Mar 28, 2010 | 01:48 PM
randyneff6971's Avatar
is the pilot jet the small 1 that requires the small flat screw driver to remove? if it is then no i didn`t remove that 1 for cleaning but i did spray cleaner through it.
I checked the throttle switch and it seems to be fine, I remover the are screw and switched it with the donor carb also blew some carb cleaner into its seat. managed to get the idle a bit lower by re-adjusting the carb but still need the choke to start it.
The quad runs fine I would just like the darn thing to start normally.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
