2006 predator 90
Old Mar 28, 2010 | 10:26 PM
pocsgray's Avatar
Default 2006 predator 90
I just bought predator 90 this week. At idle it seems ok but when my son goes for a ride it seems to smoke alot. is that normal or is something wrong. again at stand still and when i rev the motor it seems fine only when he goes for a short ride it seems to smoke alot. it has been along time sense i had a two stroke so not sure.
Any help
Thanks
Old Mar 29, 2010 | 08:54 PM
IF it doesn't smoke I'd worry about it! Normal for it to smoke a little more after warming up,because its heating up the exhaust pipe and muffler which over the years gets a little carbon/oil build up and tends to add to the smoking. If gets too bad you can remove it and have it boiled out. Machine shops can do it for you. Also check that you have a good air flow out of the muffler,I've had em almost stop up from carbon on older machines. Good luck
akguy31
Aug 31, 2019 04:34 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
clscott84
Sep 21, 2015 10:16 AM
Elkaholic
Sep 6, 2015 02:44 PM
snowolson
Aug 31, 2015 03:51 PM
