Broken Bleeder
Old Apr 5, 2010 | 09:48 PM
p00hbear's Avatar
Default Broken Bleeder
Broke off the bleed on the rear caliper of a 98 400 xplorer... How do you guys feel about a drill and tap? That is so long as the shavings get cleaned out? Aside from another caliper have any options?
Old Apr 5, 2010 | 10:17 PM
switzomatic's Avatar
You can try using an extractor but be careful. If it doesn't start backing out you'll have to go with drill/tap method. Had the smaller extractors break when using on bolts because they can't handle too much.
Old Apr 5, 2010 | 10:19 PM
p00hbear's Avatar
this is pretty well in there... I dont see an extractor or easy out doing it... I guess its drill and tap time..
Old Apr 5, 2010 | 10:20 PM
Mikka's Avatar
took one off on a trail boss with one of those, lots of break free oil, some patience and comes out easy once you get it going.
http://z.about.com/d/homerepair/1/0/..._extractor.jpg
Old Apr 6, 2010 | 05:54 AM
ftwflh's Avatar
You can get a bleeder repair kit at a good auto parts store
Old Apr 6, 2010 | 08:29 AM
bueller's Avatar
I also broke the bleeder on the rear caliper of my '97 Trail Boss. This is what I did, NOTHING!!! When it broke I had already completed bleeding the line. It is tight enough so that it doesn't leak and broke off clean enough to prevent vise grips or other methods of easily backing it out. Since it broke all brakes on this machine have been working great, including the foot brake that I adjusted : ) I fully expect to go years without having to worry about the broken bleeder.
Old Apr 6, 2010 | 08:34 AM
p00hbear's Avatar
bleeder repair kit eh? Ill check that out... Is it basicly A tap and different sized bleeder?
And I need to bleed mine so Im not as lucky as you got with yours... but thanks for the reply
Old Apr 6, 2010 | 05:56 PM
ftwflh's Avatar
Basicly that is it
Old Apr 7, 2010 | 10:59 AM
tw1st3d1's Avatar
Find a nut just a bit larger than the bleeder valve, place it over it, tack weld the nut to the broken bleeder (works best with a mig welder, and turn it out. This does 2 things, it gives you something to turn it out with, and also heats it up just enough to swell the metal to break the rust free. I do this all of the time for friends and such. Just did an exahust manifold bolt in an aluminum head, and also a tiny screw in a disrubutor in the last week.
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
awer1968
Sep 8, 2015 11:02 AM
