Running ATV in AWD?
Old Apr 6, 2010 | 02:43 PM
Cookie66's Avatar
Default Running ATV in AWD?
Dose running an ATV in AWD use more gas to run? Also, should you drive it in AWD all the time? Thanks!
P.S. There is a switch on the ATV to turn on AWD or 2 wheel drive.
Old Apr 6, 2010 | 02:50 PM
DODGE57HEMI's Avatar
Mopar Man!
Wont hurt either way!
Old Apr 6, 2010 | 02:56 PM
switzomatic's Avatar
Fronts won't spin on the newer ones until the rears get loose for 1/5 a turn so you're not going to hurt anything or burn much more gas. Personally, I don't have mine in awd until I'm going in to someplace I will need it. Old habits die hard!
Old Apr 6, 2010 | 02:57 PM
Running it in AWD will make it harder to steer when the front end is engaged. May lose a little bit of gas mileage. You can shift in and out of 2wd and AWD on the fly if you want. Just don't shift between low and high on the fly. Not good for the transmission. The Polaris system only engages AWD when it senses a difference in speed between the rear and the front tires. The one thing I wouldn't do is jump in AWD.
Old Apr 6, 2010 | 04:13 PM
bitterfitter's Avatar
I leave mine in AWD unless I specifically want 2WD. I don't sweat it.
Old Apr 6, 2010 | 04:42 PM
bentarrow's Avatar
First Things First!
Like Moose said it will be harder to steer, very noticeable on our 500s. When making a turn on a tight trail it might surprise you right into a bank.
Old Apr 6, 2010 | 06:23 PM
fishycliff's Avatar
can i switch to awd at any speed mainlyaround 10 to 15 with out blowing something out on my 05 600 twin been stopin to do it scared to tear it up
Old Apr 6, 2010 | 07:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as long as your just going along normaly and not spinning you can switch into awd w/out hurting anything
Old Apr 6, 2010 | 09:07 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Rule of thumb....as long as you use your right thumb to engage 4x4 it is impossible to dmamage anything because the wheels cnnot spin if you are not on the throttle.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
