runs rough
If I'm not mistaken, I believe fault code 51 has to do with one of your injectors. Which would make sence if it's running rough at times.
51-injector #1 open load
51-injector #1 short circuit to ground
51-injector #1 short circuit to battery
I checked wiring to injectors and injectors with meter they test ok my son tells me that it does this went hot only. I will pick up new plugs and fuel filter asap . When I took it apart I found 3/4 of air intake tube covered with the black foam that holds the tube in place . Is there a way to clear the fault without handset at dealer
SOLOLUCKY
Oct 4, 2024 09:09 PM
