06 Sp 450 solenoid problem?
Old Jun 5, 2010 | 04:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by justinary
ok well i just started the rewire on a ssr 250cc china quad well first no good so now im going to do this in questions 1 at a time ok i got my + from battery to syliniod then from syliniod to starter off the syliniod is 2 wires red/white and a black on can anyone tell me were these go so i can get this thing turning over.i got it with no good wire harness starting from scratch so please be gentle and ya alkl i want to run is what i need to nothing else lights sensors key nothin kill/run/start,starter,regulator,cdi thats all i want thanx again guys
depending on if your solenoid has 2 wires(not the big side cables which you hooked up right by the sounds) the red maybe red/white should trace back to the switch or push button(what ever starts that bike) and is a hot wire once the button is pushed/key is turned. this wire is has power going thru it to the solenoid only when you hit the start so it will energize the solenoid to start the bike. so basicly you need the key switch or off and on switch to be wired right as to make that wire a hot wire. hope you understand what i mean.
txpedsrt1
Feb 3, 2017 08:07 PM
JoAnnS
Jul 23, 2015 02:18 PM
Chuck188
Jul 17, 2015 02:45 PM
Chocobamofo
Jul 10, 2015 07:46 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
