Checking compression
Old May 14, 2010 | 10:47 AM
hvychevy's Avatar
Default Checking compression
right now the engine on my 1996 trail blaz2er does not run and i know i need to check compression but is it ok to check using the pull start as my starter is fried also
Old May 14, 2010 | 11:31 AM
TLC's Avatar
TLC
Does'nt matter how you turn the motor over when testing the compression. 3 pulls should do it.
Old May 14, 2010 | 05:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
usually like on a 2 stroke you would hold the throttle wide open on a cold engine and crank 5 times for the best result. imo
slowgsxr97
Mar 18, 2022 03:40 AM
Big bousse
Sep 26, 2015 10:42 AM
manuelrivera
Aug 8, 2015 04:34 PM
NatePerz
Jul 27, 2015 03:27 AM
ghost civic
Jul 19, 2015 10:13 AM
