Need help!
Old May 15, 2010 | 09:38 PM
grossroads28's Avatar
Exclamation Need help!
I have an '85 Trailboss 250 & in desperate need of some parts. I am looking for a rear brake like, caliper, & rotor. Do you guys have any tips as to were I can find them? Do you know how I can figure out what parts from other models may fit this? I really appreciate any help!!
Old May 16, 2010 | 06:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome. you may try ebay or a salvage yard. as far as other models fitting you can check on the polaris parts break down to cross referance what else they will work on.
well i descided to do a little leg work for you and found that the caliper was only used on 85&86 t.boss and scramblers. the disk was used on a few differnt bikes up to 91 6x6's and other bikes. now the web site says the part no# 1910026CALIPER, BRAKE IS [No Longer Available]this is right off polaris web site. hope this info helps you. oh here is the disk no's# 1910021DISC, BRAKE Substituted by 1910087
Old May 16, 2010 | 03:05 PM
ftwflh's Avatar
I dont have a rear caliper(85-87 work) but I do have some other parts for early Polaris so if you find you need some thing let me know.
Old May 18, 2010 | 02:13 PM
Right now I need the rear brake cable, rotor & caliper. I will let you know if there is anything else I need. I am sure there wil be something else soon! Thanks a bunch.
Old May 18, 2010 | 02:16 PM
Thanks for the info! It does help a lot. I know I can't order it new from polaris, bike bandit, or babbits. Were did you find the parts break down? Is it on the polaris site? I REALLY appreciate your help!
