ebs bushing
Old May 17, 2010 | 09:57 AM
Polaris500Sportsman's Avatar
Default ebs bushing
I have 06 sportsman 500efi and its really hard to shift ranges, so I'm thinkin maybe the ebs bushing is worn out?? Also when its sittin in high, low, or reverse there's a slight whine coming from the clutch it sounds like? I'm thinkin it could be the belt??
Old May 17, 2010 | 03:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does the bike want to creep ahead? the wine could be the belt actually burning as your sitting there if its rubbing. check to make sure the bike is isling around 1200 rpm's as well. it could be the ebs bushing or the fiber type washers on either side.
Old May 17, 2010 | 07:23 PM
yeah it does wanna creep when sitting idling and idles around 1200 +/-100 rpms
Old May 17, 2010 | 08:02 PM
UTU's Avatar
UTU
try 1150 idle. Look at the belt with cover off belt should ride in center of primary not touching primary sheaves. Secondary should not be turnind when idling / very little if any.
Old May 17, 2010 | 09:12 PM
Thanks for the help fellas. I will check everything out and take a good look at the belt
Old May 17, 2010 | 09:35 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
May need a new belt. A Worn out belt will ride low on the pulleys causing a slight creep. Depending on the mileage and sage the belt may be worn.
Old May 18, 2010 | 04:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it is also possiable that the belt can shrink if it was hot and got cold water on it as well. happened on my 02' 500
Old May 18, 2010 | 09:03 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Here is the fix, fiber washers are shot
Old May 18, 2010 | 04:34 PM
went to the dealer today and he gave me 4 shims and said the clutch is mis aligned. would a mis aligned clutch cause the slight whine when its in gear? im thinking that if the clutch is mis aligned then the belt isn't riding where its suppose to causing the whine?
Old May 18, 2010 | 06:19 PM
I would rebuild the primary starting with the fiber washers
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
