braided brake lines
Old May 19, 2010 | 09:32 AM
blackwidowpolaris's Avatar
Default braided brake lines
I was wondering if anyone has tried to put late model steel braided brake lines on a older sportsman.I have a 98 sportsman with a cracked front hose and thought maybe i could upgrade to the better hoses. someone let me know if it will work...thanks
Old May 19, 2010 | 02:15 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
As long as the length and fittings are the same, I can't see any reason why not.
Old May 20, 2010 | 09:16 PM
Steve L's Avatar
I went to the local hydraulic shop and had them make a set for the rear of my scrambler when I extended the swing arm. $70 for three inch extended lines with the correct fittings at both ends. They also had a choice of red, blue, black, and clear/stainless colors. The used Earl's parts.
Old May 21, 2010 | 08:06 AM
ftwflh's Avatar
good up grade.Your brakes wont get spongy on hot day or with hard use
Old Jun 3, 2010 | 02:35 PM
i found a complete set of braided brake lines on ebay off a 2006 sportsman for 30 bucks. they work great. just in case someone wants to upgrade too...
1ArmBandit
Sep 8, 2015 08:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
