Magnum frount ball joint help.
Need some help guys, the wifes 02 magnum lost the ball joint on the right frount lower joint to the a-arm. Im glad she wasnt moving very fast. Anyway Im having a difficuilt time removing the ball joint housing. The knuckle is still attached to the shock, thinking about removing so I can use the vice. I've tried PB blaster heat and a vice grip until there's not enough left to grip. Thought about drilling through the knuckle so I could get some oil but not sure if that will really help. Im at a lost guys so any help would be great.
If you have the puller for the ball joints you could weld the old stud back in the joint itself and pull it normally. Ive done that hundreds of time. just weld it in as straight as you can. If you don't have the puller, you could weld it in and take the strut to the dealer and let them pull it, then you install the new one yourself. it wouldn't take them 5 minutes. i can't imagine it would cost too much to do it that way.
