Electric issue it seems, Xplorer 500, help
Old May 20, 2010 | 08:40 PM
sacr3's Avatar
Question Electric issue it seems, Xplorer 500, help
Hello, recently i've purchased a 1997 Xplorer 500, and she runs fine but when I had the battery checked, turned out to be dead.
Well now I have a new issue, I got a new battery, charged it, placed her in.. and now Something weird is going on.
The front lights dont turn on, even when she is running, Cept on low beams. The front right light turns on when its on low beams, but on high, nothing. The high beam indicator light doesn't come on either. Nor does my "Neutral" light. Nor does my back light, even when the brakes are pushed.
The AWD and Reverse come on, and the Reverse override works properly.
The starter is finiky too, I press "start" and i hear nothing. Not even a click.. I press again, and again, and again and all of a sudden she starts..
Now i'm not sure whats going on here
Doesn't work
-Starter button (sometimes it does)
-Front lights on High beams
-Only front left light on low beams
-High beam indicator light
-Neutral light
Does work
-Reverse light
-Starter button (sometimes)
I have 2 reds connected to positive, and 2 blacks on negative, plus a Green wire on black. They're on there good.
I have to mention too that when I had it on, I disconnected the old battery.. The front lights stayed on for the most part but when I rev'd the motor they went bright, flickered, then turned off. They wouldn't work at all but now the front right light works on low beams only.
Sorry if i'm dragging this on, but if you can throw a few suggestions my way that would be great. Not sure whats going on here, tempted to take her apart 100% and see if all the wiring is ok..
Thank you
Old May 20, 2010 | 09:00 PM
ramman67's Avatar
Default lights
sounds like you burnt the light bulbs out.I would check you bulbs and check to see if you have power to your starter when you push your start button.If you have power then starter probably needs rebuilt.
Old May 21, 2010 | 06:59 AM
Kerbbirds's Avatar
When it had no battery in it it blew all the bulbs, the battery acts as a buffer in the charging system, without it the bulbs get too much voltage and they blow, take all the leads off of the selenoid, under left rear fender, make sure they are clean and tigthten the nuts that are under the battery cables, if that doesn't fix the starting, jump across the posts on the selenoid, if it starts right it needs a selenoid, if its still not right could be rhe starter needs brushes or cleaned or a new one...
Old May 21, 2010 | 02:23 PM
sacr3's Avatar
K so the starter is fine, when i make contact with the wires (Skip the solenoid) she starts just perfectly
But that darn solenoid, is it supposed to be grounded somehow? When i rub it hard against metal sometimes it clicks.. and 90% of the time it don't..
Sounds like i just need a new solenoid?
Can it be any? Or does it have to be specific to this atv?
Thanks
Old May 21, 2010 | 04:21 PM
4getful2's Avatar
i know what you're saying,like a ford style relay?? it's pretty tight fit you could try an old dodge 70's style relay that might work
Old May 21, 2010 | 04:56 PM
Kerbbirds's Avatar
I dont think the right one is too expensive, call your stealer dealer and ask , you can also look it up on bike bandit
skinnyr6
Aug 25, 2023 02:18 AM
DeFox500
Jul 26, 2015 06:32 PM
Bratman2
Jul 23, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
