Testing an Xplorer 400 Coil
Old May 20, 2010 | 09:39 PM
twin80's's Avatar
Default Testing an Xplorer 400 Coil
I haven't picked up a Service manual yet so I thought I would ask if anyone knows the coil specs for testing purposes.
Old May 21, 2010 | 08:04 AM
ftwflh's Avatar
Turn the key on take the plug out hold plug pull rope if it bites coil good.
If you need one I have a used one drop a PM
Old May 21, 2010 | 08:17 AM
twin80's's Avatar
It's torn down at the moment for a top end rebuild. The coil came in a box with a few other odds and ends when I bought it so I can't use that method.
I'm really hoping to measure Ohm resistance with a multi-meter. I just need to know what the "good" range will be.
I will def take you up on the offer if I wind up needing a coil.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
