99 500 magnum
Old Jun 1, 2010 | 07:41 AM
jughead2's Avatar
Default 99 500 magnum
is there any way to change the caster on a magnum 500? mine has been extremely hard to steer from day one. it is a 4/4. just found this site. any and all help would be appreciated
Old Jun 3, 2010 | 07:44 PM
jughead2's Avatar
guess the old man is asking the impossible but this thing is harder to steer than ANY 4 wheeler i have ever ridden
Old Jun 4, 2010 | 07:31 AM
TLC's Avatar
TLC
Have you change your front hub AWD fluids? Sounds like one Hilliary is not releasing. Go in reverse while in a sharp turn for a few yards,that usually unlocks it.
Old Jun 4, 2010 | 08:06 AM
jughead2's Avatar
Default 500 magnum
have had that problem. this is different. it is i am almost sure way to much caster in the front wheels. steers easy backing up. but thanks for the reply. keep them coming interested in all suggestions.
Old Jun 5, 2010 | 08:38 AM
ftwflh's Avatar
Sounds like the hubs are not releasing.
Old Jun 5, 2010 | 03:46 PM
jughead2's Avatar
definitely know when the hubs dont release old man cant steer then for sure
Old Jun 5, 2010 | 08:27 PM
Kerbbirds's Avatar
take a piece of string. tie to the trailer hitch around rear tire, past front tire, hook it to a jack stand, make string just touch the front of rear tire, measureoff of front and rear of front wheel,should be set straight ahead or toed out 1/16to1/8 inch, as for caster. are your fron springs worn out and sagging?
Old Jun 5, 2010 | 08:42 PM
jughead2's Avatar
have checked toe in. i bought this thing new dealer wouldnt or couldnt do anything about it. was more interested in selling them than follow up on problems. hard to steer from day one
Old Jun 9, 2010 | 09:44 AM
chopperdude's Avatar
Thats pretty slick idea ) I need to try that myself )
Old Jun 9, 2010 | 03:14 PM
Kerbbirds's Avatar
Right out of an older polaris service manual.
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
