wont start
Old Jun 26, 2010 | 10:07 PM
polaris699's Avatar
Default wont start
i was just wondering if somone could help me i have a 03 polaris trail blazer it will start with the rope but not the key (if i crank the hec out of it some times it will start ) new battery plug fuel filter cleaned all the conectors
Old Jun 29, 2010 | 06:53 PM
Russ7R's Avatar
How fast is the starter turning it over? Did you check the compression, sometimes when it is low it is hard to start, how good is the fuel, and lastly spark plug gap?
R
Old Jun 29, 2010 | 06:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure there is good connections and try pulling the plug out and crank it over to see if your gettung any spark.
Old Jun 29, 2010 | 08:52 PM
polaris699's Avatar
there is spark fresh 92 octain gas good compression and gap is good if i unplug the ignition and let it sit over night plug it back in the next day it will start twice with the key then it wont anymore i have done that a few times and it is the same everytime thank you for your info but have alredy tryed all that if anyone hase any other ideas please help runs grate after started
Old Jun 29, 2010 | 10:02 PM
biggerten's Avatar
Cranking the motor will draw the battery voltage down (and any questionable connections will only make it worse). Lower voltage = weaker spark. Pulling the cord does not place a load on the battery, hence higher voltage and a stronger spark. If indeed you are sure the connections are all good, I'd start to give the battery the evil eye, even if it is new. Stranger things have happened. But a bad connection at the battery (+ or -), bad cables/crimp connections or connections at the solenoid seems to me to be the most likely culprit.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
