08 polaris outlaw 525 irs
Old Jul 6, 2010 | 07:28 AM
golftek's Avatar
Default 08 polaris outlaw 525 irs
recently purchased new 08 outlaw 525irs and have same problem with backfiring and hesitation when starting out. would like to try a jet kit. live in pa. where altitude ranges from 1500-2500 ft. would like to know which kit to try as there are different ones and different stages. any help would be appreciated. thanks.
Old Jul 6, 2010 | 11:43 AM
BPM's Avatar
BPM
I've heard this to be a problem with outlaws. I think I read some wear that the head pipe don't line up right with the exhaust pipe. your getting a leak which makes it back fire.
There is a fix. Do a search and you should be able figure it out.
Old Jul 7, 2010 | 01:05 PM
SCRAMBLER500XXX's Avatar
THE HEAD PIPE IS TO LONG, remove exhaust pipe and trim about 1/8 inch from exhaust pipe where it connects to the exhaust manifold, the pipe hits the spring tabs before it has a chance to seal.
Old Jul 7, 2010 | 04:48 PM
golftek's Avatar
Default 08 outlaw 525irs backfiring
thanks. checked it out and definetly leaks around exhaust pipe on one side. took it apart and going to take it to work tomorrow where i have better tools to trim pipe. thanks for info. i'll let you know if it worked.
Old Jul 8, 2010 | 06:46 PM
golftek's Avatar
trimming pipes didn't work. still leaks. seemed tight until i tightened the manifold bolts. think i might weld pipes to manifold. anyone ever done that?
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
