2003 Polaris Sportsman 90- Smoke
Old Jul 23, 2010 | 12:50 PM
TGUNN's Avatar
Default 2003 Polaris Sportsman 90- Smoke
I recently purchased a 2003 Polaris Sportsman 90 in really good condition and not much use. I was wondering how much smoke is normal out of the exhaust when my daughter is riding it ? I'm not sure what type of two stroke oil the previous owner has in it but I'm still on his fill up. I plan on using Yamalube 2 stroke oil in it when it's time to fill. I'm not real familiar w/ how much smoke is normal from a two stroke like this. My other daughters quad is a 07 Suzuki LT 80 and it doesn't smoke as much as the Polaris. I am wondering if too much oil is mixing in the gas and if there is a adjustment for it on the carb somewhere? When it is running I can see a little oil like substance at the end of the exhaust pipe. Any help would be appreciated.
Old Jul 23, 2010 | 10:10 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Take baffle out of muffler and clean it, it could be trying to stop up.....If it,s not removeable then may have to remove exhaust system and heat up with lite weight torch and heat up !alot of time mini quad don,t get rode hard and exhaust get gummed up.... most of the time this is caused by bad quality oil....Good Luck....P.S this is only my opinion thou....
Old Jul 23, 2010 | 10:27 PM
Bing43's Avatar
Follow the throttle cable down one goes to carb other cable goes to oil pump. There is a mark on pump arm and one on pump, marks should line up at 0 opening of throttle if not there is adjustment there to line them up and you can add more oil or give motor less oil by adjusting cable.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
