Is it a stator issue
Old Aug 25, 2010 | 04:34 PM
Cypher's Avatar
Unhappy Is it a stator issue
Hi Guys,
I have an 04 Polaris 600 Twin. I has less than 800 miles on it(garage kept) and it ran great up until I put a winch on it. I put a Gorilla 3000Lb winch on it at the beginning of the year. Everything went fine and I only used it once or twice to help a neighbor move an od car around. I started to notice that every couple of weeks that my battery(new last lear) was all of a sudden showing a 50% or more loss when plugged in to the charger. I ran it every week or two araund the neighborhood to charge it and it would always crank up ok. Then a couple of months ago the discharging began to get worse. I could charge it up and it would hit around 75% on the meter and quit charging. I would leave it for a day and plug it in and it would hit 100% charge level. When I try to start her up after charging it used to start up and idle ok, now when she cranks up it takes a little throttle and when I put it into reverse it flat out dies. If I put it into drive (L or H) I can drive it. I also noticed that the speedo showed I was doing 30-40 at a stand still. Even when I was moving it would act crazy. I though it migh have be the Gorilla so I unhooked it...same results! Now on the speedo It shows stator. Anybody care to give me some pointers as to where I need to look first. I found the maintenance manual and just wanted to ask first so I dont end up chasing my tail. Thanks for the help.
Old Aug 25, 2010 | 07:05 PM
Overdrive's Avatar
The speed sensor can cause the problem with the speedo and dying in reverse.
Unhook it from the speedo and see what happens.
Old Aug 26, 2010 | 12:09 PM
Cypher's Avatar
Default Thanks for the heads up!
I will start there and work my way back. I think I remember that it is on the front left wheel on the 600.?
Old Aug 26, 2010 | 06:15 PM
Bowana's Avatar
Hi,
Don't give up on that battery being the culprit. I had a buddy of mine tear his 06 800 all apart and change the stator and have his bike down for a long time l;ooking for the problem when it was the battery itself all along. He had purchased a new battery and ran it a few times, went hunting and it left him in the bush. Thinking it was not the battery he looked everywhere else but there.
Just saying!
Old Sep 26, 2010 | 07:17 PM
Cypher's Avatar
Talking It is fixed!!
Thanks for the heads up about the battery! I put an AGM batt in and it now works like a top! $90 is a lot better than $495 for a new stator. Whew!!
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
