Im having some trouble with my 02 sportsman700
Old Sep 18, 2010 | 07:23 PM
  #21
Kerbbirds's Avatar
I wonder if the etc on the throttle cable is adjusted right?
Old Sep 22, 2010 | 01:06 AM
  #22
jlong28's Avatar
well I went to my brothers the other day to work on my quad a little and have determined that it is the carb. I was running it down the road and got to start acting up and then pullid the choke out a little and it went away until I pushed the choke back in. Then I put it in park and reved it till it started to bog. So thats why im thinking that it is the carb and not the cluch. I want to check the air/fuel mix but not really shure where to check it at. If anyone has a pic or a diagram of where I can find it at would be helpful. Thanks Jeff
Old Sep 22, 2010 | 08:59 AM
  #23
TLC's Avatar
TLC
This for a Keihin CV carb not a Mikuni but it helps explains things. Care & Feeding Of The Keihin Carb
Old Sep 25, 2010 | 07:36 PM
  #24
jlong28's Avatar
well I think that I have found the problem. My intake boot was cracked at the bottom and my needle was on slot #4. I havent run it yet cause I need to get a new boot but almost sure that it will fix it. Will know next week cause need to get the boot.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
