Help for my 4oo Scrambler
Old Sep 18, 2010 | 05:58 PM
Madvmax's Avatar
Default Help for my 4oo Scrambler
I have a 400 polaris scrambler, 2 stroke. It starts and runs fine until it warms up then it starts sputtering. I have rebuilt the carb, and still have this problem. Replaced the reads and still same problem. You can tell were it has some seapage around the head. Please help. Thankyou for your input and time. Madvmax
Old Sep 18, 2010 | 07:50 PM
Bing43's Avatar
Check your battery was told a bad or weak battery on 400's would cause a sputtering when warmed up.
Old Sep 18, 2010 | 07:57 PM
Madvmax's Avatar
Default Sputtering
Do you know how a bad battery would cause this problem. Thankyou
Old Sep 18, 2010 | 09:50 PM
4getful2's Avatar
do you have a spare spark plug,that you can check the spark when cold, then check it again when it starts acting up.
shouldn't be any seepage on the head, you could check the compression also
Old Sep 18, 2010 | 10:04 PM
Madvmax's Avatar
Default I will get another Plug and check it
Also what do you mean by checking the compression. when its hot and cold. What about spraying carb cleaner around the head when its hot like you would on a car for a vacum leak. Thankyou Madvmax
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
